chopin70
May 28, 2016Virtuoso
Nighthawk rooters and https admin GUI
Hi, Why we still don't have any option to access GUI management through https and disable http, either for remote management and for local management Using http any being impossible to disabl...
- May 29, 2016
Sorry, I meant page 160. The example shows: http://134.177.0.123:8080 when it should be https://137.170.0.123:8080.
On page 159, the picture shows Remote Management Address: https://0.0.0.0:8443.
chopin70
May 29, 2016Virtuoso
I see nothing relevant P180 !
Remote management is in P159-160
It definately shows using http through a custom port, no SSL through 443 port
TheEther
May 29, 2016Guru
- chopin70May 29, 2016Virtuoso
Sorry, you are right, I missed in GUI Setup the https and I trusted the web and manual text
Can you confirm that access through http is actually disabled remotely ? That is if you try through http it will not be allowed?
I will rise a features to add about https only access through LAN
Many thanks
- TheEtherMay 29, 2016Guru
I'm running 3rd party firmware so I can't personally confirm that http is disabled. It would be simple enough for you to test via a smart phone connected via cellular.
