Sezro626
Nov 12, 2021Guide
Nighthawk router blocking Xfinity website
I get the below error when trying to log into my account. Also I can't use my Xfinity apps do to this as well. This randomly happened after I updated my Xfinity app. I thought that was the issue but ...
Sezro626
Nov 13, 2021Guide
plemans wrote:what modem/gateway is the R7000 connected to?
have you tried a different dns provider?
It's connected to a Motorola MB7420 modem. I'm not sure how to use a different dns provider.
Nov 13, 2021Guru - Experienced User
You could try googles at 8.8.8.8 or 8.8.4.4
https://kb.netgear.com/30510/How-do-I-set-static-Domain-Name-System-servers-on-my-NETGEAR-router
- Sezro626Nov 13, 2021Guide
plemans wrote:You could try googles at 8.8.8.8 or 8.8.4.4
It's saying I'm not connected to my network.
Trying to connect to your control panel?
You may not be connected to your Router’s WiFi network.
To access routerlogin.com, your device must be connected to your Router’s WiFi network. Check your current connection and try again.
The easiest way to manage your router’s settings and wireless network is the Nighthawk app. Learn more at the link below:"
- plemansNov 13, 2021Guru - Experienced User
Try using its ip address to connect to the router.
