Sezro626
Nov 12, 2021Guide
Nighthawk router blocking Xfinity website
I get the below error when trying to log into my account. Also I can't use my Xfinity apps do to this as well. This randomly happened after I updated my Xfinity app. I thought that was the issue but ...
Sezro626
Nov 14, 2021Guide
plemans wrote:Try using its ip address to connect to the router.
I selected "Use These DNS Servers" and changed it from automatic. But it still doesn't work. I guess I'll just live with not accessing my account. :smileyindifferent:
Nov 15, 2021Guru - Experienced User
You could also try updating to the 1.0.11.128 firmware for that router
- Sezro626Nov 20, 2021Guide
plemans wrote:You could also try updating to the 1.0.11.128 firmware for that router
Could you let me know how to download the latest firmware? I no longer see it when I log into my router. I'm currently using V1.0.11.123_10.2.100
I prefer to download through the router than the manual download.
- FURRYe38Nov 20, 2021Guru - Experienced User
You can find all versions of FW here which can get updgrade thru the routers web page:
https://www.netgear.com/support/product/r7000.aspx#download
FURRYe38 wrote:You can find all versions of FW here which can get updgrade thru the routers web page:
I just did a manual update to V1.0.11.128_10.2.112 and it's still not working. I guess I'll just thrown in the towel now. :smileyindifferent:
- michaelkenwardNov 21, 2021Guru - Experienced User
You may prefer it, but from messages appear here, that process has a higher probability of breaking a router than the manual process.
Updates over wifi are even more prone to disaster.
Your call, but I thought it worth adding a warning.
- plemansNov 21, 2021Guru - Experienced User
Does it work if you hardwire a pc/laptop directly into the modem? I know its worked on your phone but did you try it with the router skipped but still using the modem connection?
- plemansNov 21, 2021Guru - Experienced UserThat would imply a modem or isp issue and not a router issue
