Sezro626
Nov 12, 2021Guide
Nighthawk router blocking Xfinity website
I get the below error when trying to log into my account. Also I can't use my Xfinity apps do to this as well. This randomly happened after I updated my Xfinity app. I thought that was the issue but ...
GregGreg
Nov 16, 2021Star
First, try to determine if the problem is with the router/ISP or with the Xfinity service provider.
If you have an application on your smartphone - see if it works by the telephone operator (WiFi off on smartfon).
If the application works on cell data, only then you will need to check the router.
Sezro626
Nov 20, 2021Guide
GregGreg wrote:First, try to determine if the problem is with the router/ISP or with the Xfinity service provider.
It works when I use my cell data.
