Sezro626
Nov 12, 2021Guide
Nighthawk router blocking Xfinity website
I get the below error when trying to log into my account. Also I can't use my Xfinity apps do to this as well. This randomly happened after I updated my Xfinity app. I thought that was the issue but ...
Sezro626
Nov 21, 2021Guide
plemans wrote:Does it work if you hardwire a pc/laptop directly into the modem? I know its worked on your phone but did you try it with the router skipped but still using the modem connection?
It does not work connected directly to the modem either.
Nov 21, 2021Guru - Experienced User
That would imply a modem or isp issue and not a router issue
