mbarnes18
Aug 24, 2021Tutor
Nighthawk router blocks microsoft remote desktop
I bought a Netgear CM700 and Nighthawk R6700 - AC1750 for my internet through comcast xfinity at my new apartment. Everything works as expected except Microsoft Remote Desktop does not work to my wor...
mbarnes18
Aug 25, 2021Tutor
Went to advanced tab, clicked internet port, changed DNS Address to "Use These DNS Servers", added 8.8.8.8 and 8.8.4.4, applied, router rebooted, tried to reconnect to MS Remote Desktop. Same error.
Went to advanced tab, WAN Setup, Checked box next to Default DMZ Server, entered IP address of my laptop. Router rebooted. Tried to reconnect MS Remote Desktop. Same error.
I also gave my laptop a static IP so it wouldn't keep moving every time I rebooted the router and tried setting up port forwarding for both port 443 and 3389 to my laptop's internal IP. Still same error.
I'm wondering if I should return my "smart" wifi router and buy a "dumb one" and hope that it's the smarts that are getting in the way of working from home. Maybe this router would work better? https://www.amazon.com/gp/product/B0756QFLXP/ref=ox_sc_act_title_2?smid=ATVPDKIKX0DER&psc=1
Aug 25, 2021Guru - Experienced User
theres a few threads on microsoft about that error.
I'd read through a few of the threads.
Error code: 0x300005f – Feedback for Microsoft Remote Desktop Clients (uservoice.com)
- mbarnes18Sep 01, 2021Tutor
I read through these topics but nothing new to try or any solutions provided. I did buy a different netgear router to see if that fixes the problem, and it does. I unplugged the R6700 and plugged in the R6230, restarted the modem and the R6230 works fine. My working hypothesis is that the R6700 is too "smart" for it's own good! Now just waiting the hear back from Netgear about returning the 6700.
