riche22
Oct 01, 2021Tutor
Nighthawk Router Extra Connection Appearing (sometimes)
Typically my Nighthawk router works amazing, but sometimes an additional wifi channel is opening up. My typically "Netgear29" will sometimes also be accompanied with a "Netgear29-5G2". This new netwo...
- Oct 01, 2021
Did this just start happening?
How long has it been going on?
there is a security hotfix you can install 1.4.1.82.
Might help/might not.
I'd recommend installing the hotfix, then doing a factory reset/reinstall.
Oct 01, 2021Guru - Experienced User
What firmware version are you on?
Are you using smart connect?
riche22
Oct 01, 2021Tutor
V1.4.1.68_1.3.28
I am using smart connect.
- plemansOct 01, 2021Guru - Experienced User
- riche22Oct 01, 2021Tutor
It has been like this for a few weeks, but I have not had time to look into it until now. I also noticed that if I login to the router through my computer, the "5G-2" network is showing a yellow triangle with a ! as opposed to a green one with a check. I'll update.
Let me know how it goes!
