tequekama
Dec 28, 2023Aspirant
Nighthawk Router Giving 400 Bad Request
Hi, I upgraded the firmware and thought nothing of it. A few weeks later I tried to login from a computer hardwired connected to the router and received first an ad for the Nighthawk App, and a link ...
Dec 29, 2023Guru - Experienced User
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration. So a factory reset is the first thing to try if you have problems with new firmware.
What NG router model do you have?
