DAK-11
Feb 06, 2021Aspirant
Nighthawk Router not connecting to HP printer
Got my new Netgear router set up couple weeks ago but one problem. I have a HP 4500 series printer and I cannot get it set up with Netgear router. I've researched online and apparently connecting a ...
sktn77a
Feb 06, 2021Virtuoso
Are you connecting via wireless or ethernet (or USB)? You have to set up the printer on your computer (windows) first.
- DAK-11Feb 06, 2021AspirantConnecting via wireless and I only have Apple products so no windows to set up. Before installing the Netgear I had no problems printing with iPhone and iPad Pro. I have a chromebook for preparing taxes for AARP Taxaide but not for personal use. It connected with previous router as well without having to set it up.
- antinodeFeb 06, 2021Guru
> [...] I cannot get it set up [...]
"cannot" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.> [...] I've researched online [...]
Thanks for the helpful links. "online" is a very big place.
> [...] Does anyone have information on connecting my printer to [...]
I'd bet that HP does. Start at "hp.com".
> [...] Netgear R7000 (AC1900)?
Firmware version? Connected to what?
> Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0Not a router. Nothing to do with anything?
> [...] Before installing the Netgear [...]What did you use then? Did the R7000 replace something, or did you
add the R7000 to some existing arrangement, or what?> [...] It connected with previous router as well without having to set
> it up."it"? Printer? Chromebook? Other? How do you connect _any_ device
to your wireless network "without having to set it up"? Have you no
security at all?- DAK-11Feb 06, 2021AspirantOk I had a TP-Link router before that printer was connected to. The Chromebook automatically connected to the old router. My iPhone and iPad Pro were set up and connected to the old router.
The HP Envy 4500 series was working just fine and don’t want to replace unless I can’t connect with Netgear router. I have downloaded the HP Smart app and no luck with that either.
