CruiseThatGuy
Nov 26, 2021Follower
Nighthawk Router not connecting to work VPN
While using my work computer (Microsoft Surface) at work I can connect to my works Remote Desktop Connection just fine for obvious reasons. If I get on other wifi networks I can connect to the Re...
michaelkenward
Nov 27, 2021Guru - Experienced User
CruiseThatGuy wrote:
If I get on other wifi networks I can connect to the Remote Desktop Connection, I just have to turn on a VPN that my work setup on the computer.
VPNs seem to be picky. And there are dozens of them. They need careful configuration with the right settings.
It might help if you said which VPN you have.You could also try a searcher for the VPN in question.
If this is a works thing, then maybe they people there can help.
I'm assuming it's some setting on my router that's not allowing the remote desktop connection. I went through the router settings, but couldn't get anything to work.
Sounds like a good guess. So tracking down which settings you need to change would be a good start. Otherwise were are all left guessing,
