kohalnity
Nov 14, 2022Follower
Nighthawk router question
I have a Charter Spectrum Modem and have my own Apple Airport Express (The flat square with the green light). It’s starting to not connect as much anymore so I went ahead and picked up the Netgear ...
michaelkenward
Nov 15, 2022Guru - Experienced User
kohalnity wrote:
.... so I went ahead and picked up the Netgear Nighthawk AXE7300.
That isn't something I can find in the Netgear system. What is the model number? Look at the label in the thing.
If this is one of the RAX devices, there may be a better help to seek help.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
