scfancher
Aug 05, 2021Tutor
Nighthawk Router Randomly disconnects from internet
I bought this router on February and it worked fine for a few months. THe last 2 months it just keeps dropping internet. It drops both wifi and direct ethernet connections. I work from home and th...
Aug 05, 2021Guru - Experienced User
You're actually 4 versions out of date on the firwmare.
The latest currently is 1.3.3.140
You might try updating to the current version, doing a factory reset, and reinstalling (don't use a backup configuration)
- scfancherAug 05, 2021Tutor
I just did that last night, so we will see how things go today. Thanks!
- newbornkilikAug 10, 2021Aspirant
Any updates? I just realized that I was a few firmware updates behind as well (auto update check could use some work) with the same issue. How is it going so far?
