Jwarwick
Jan 05, 2022Follower
Nighthawk router work with nighthawk mesh system
So i have a NETGEAR Nighthawk 6-Stream AX5400 Dual-Band Wi-Fi 6 Gaming Router (RAX50-100CNS) and its just not providing ideal internet in every room in my home. (3 story plus basement). Trying to find...
Jan 05, 2022Guru - Experienced User
No. They wouldn't integrate.
You could use them together but not using the same ssid/roaming setup.
I do something similar with a flagship router as my primary and my mesh system running in access point mode. (with the mesh on a seperate ssid) It lets me put the stationary devices (that are close) and my devices needing maximum speed on the flagship router and the devices that roam or that are futher away on my mesh system. Provides good coverage and peak performance.
