miterkint
Dec 22, 2021Follower
Nighthawk router worth it? I will get a modem too
Currently in the market for used modem and routers. I am thinking about getting a night hawk router ac1900 used for cheap under 50 if I can. Then I will probably need a modem too. Now I am pretty ignorant to modem and routers but want something that is good since I am a gamer and plan to use this for a long time. Does it matter what modem and router I buy or can it all be used regardless of the internet providing company?
I will be moving into a new place so need internet.
1 Reply
You need to find out who your provider is and what speed you plan on subscribing to. Then you can check what devices are comptible with those speeds/ISP.
The ISP should have a compatibliity list.
