larry18446
Dec 26, 2019Aspirant
nighthawk router
I just purchased a robot vacuum and it comes ith an app. The vacuum will only work with 2.4 and my router is set for 5.0 I don;t know how to configure the router- WIFI on my phone only shows netge...
- Dec 26, 2019
> I don;t know how to configure the router- [...]
There's a pretty effective remedy for that. Visit
http://netgear.com/support , put in your model number, and look for
Documentation. Get the User Manual (at least). Read.
antinode
Dec 26, 2019Guru
larry18446
Thanks- apparently the ON/OFF button was not in the correct setting-
amazing what a few words can do to clarify-
No, I don't feel too stupid!!!
thanks again
- antinodeDec 26, 2019Guru
Thanks for the update.
Ignorance is often curable. (Stupidity often goes unrecognized, and,
even if recognized, can be refractory.)
