norcaldsm
Dec 04, 2023Tutor
Nighthawk routers and saving settings (IP forwarding, DHCP reservations) workaround
With the latest firmware, the Nighthawk router has lost its ability to save changes to numerous fields in the configuration manager. Attempting to set a DHCP reservation or IP forwarding no longer wo...
michaelkenward
Dec 04, 2023Guru - Experienced User
Any particular router and/or software version? Just those you have tagged? (None of which is covered in this section of the community for Nighthawk with WiFi 6 (AX) and WiFi 6E (AXE) Routers.)
That detail could be useful when people turn up here asking for help.
That's not an issue I recall seeing here for many devices.
I didn't see it on my R7000P. But I wasn't port forwarding.
