norcaldsm
Dec 04, 2023Tutor
Nighthawk routers and saving settings (IP forwarding, DHCP reservations) workaround
With the latest firmware, the Nighthawk router has lost its ability to save changes to numerous fields in the configuration manager. Attempting to set a DHCP reservation or IP forwarding no longer wo...
michaelkenward
Dec 04, 2023Guru - Experienced User
Any particular router and/or software version? Just those you have tagged? (None of which is covered in this section of the community for Nighthawk with WiFi 6 (AX) and WiFi 6E (AXE) Routers.)
That detail could be useful when people turn up here asking for help.
That's not an issue I recall seeing here for many devices.
I didn't see it on my R7000P. But I wasn't port forwarding.
norcaldsm
Dec 04, 2023Tutor
This should be a workaround for all Nighthawk models.
- michaelkenwardDec 04, 2023Guru - Experienced User
OK.
Anyone know which ones have had this issue?
- schumakuDec 05, 2023Guru - Experienced User
Uneducated guess norcaldsm does talk about the R8000P and it's inability to pass MAC addresses in the Web browser, e.g. for DHCP address reservations.
These are things happen if some community members are publishing vague Beta firmware, without insight or details. Beyond me why Netgear does fail to fix such issues within reasonable time, considering fixes might exist - three months later, it appears to be a big secret.
The magic fix for "every" Nighthawk seems to be to manipulate the MAC address in the wonderful Web UI code 8-)
- michaelkenwardDec 05, 2023Guru - Experienced User
Indeed. Seriously baffling.
Hardly a responsible Netgear response to rely on some unknown intermediary to act as a corporate go between.
