norcaldsm
Dec 04, 2023Tutor
Nighthawk routers and saving settings (IP forwarding, DHCP reservations) workaround
With the latest firmware, the Nighthawk router has lost its ability to save changes to numerous fields in the configuration manager. Attempting to set a DHCP reservation or IP forwarding no longer wo...
norcaldsm
Dec 04, 2023Tutor
This should be a workaround for all Nighthawk models.
michaelkenward
Dec 04, 2023Guru - Experienced User
OK.
Anyone know which ones have had this issue?
- schumakuDec 05, 2023Guru - Experienced User
Uneducated guess norcaldsm does talk about the R8000P and it's inability to pass MAC addresses in the Web browser, e.g. for DHCP address reservations.
These are things happen if some community members are publishing vague Beta firmware, without insight or details. Beyond me why Netgear does fail to fix such issues within reasonable time, considering fixes might exist - three months later, it appears to be a big secret.
The magic fix for "every" Nighthawk seems to be to manipulate the MAC address in the wonderful Web UI code 8-)
- michaelkenwardDec 05, 2023Guru - Experienced User
Indeed. Seriously baffling.
Hardly a responsible Netgear response to rely on some unknown intermediary to act as a corporate go between.
- FURRYe38Dec 05, 2023Guru - Experienced User
Only effects the P series model routers and yes, NG has beta FW that fixes this. No idea why they haven't officially released it.
