ecgardner
Feb 19, 2021Follower
Nighthawk speed and connectivity issues
The router with satellite was working well - then in last few days varying speeds from under 1 mps to over 200.
Now my laptop does nor show up as connected on the Network map, and speeds are under 25 mps.
When I do a speed test on teh software it 800, my phone is over 400.
My warranty ran out a week or so ago.
I reboot the system with no progress...
What is going on?
1 Reply
- DarrenMSr. NETGEAR Moderator
Are you still having speed issues or did that go away? What firmware version are you on and what is the model of the router?
