jymaillat
Mar 19, 2018Tutor
Nighthawk Stopped Broadcasting Signal
I have a Nighthawk R7000 wifi router linked to an Arris modem (for cable access: internet, TV, phone). I had four networks (two 2.4GHz and two 5GHz). And I had two iMacs, two iPads and one printe...
- Mar 20, 2018
Thank you. I did that last night before going to bed and this morning all did indeed come back to normal.
michaelkenward
Mar 20, 2018Guru - Experienced User
Thanks for the confirmation. It is easy to overlook that, which is why the issue comes up here pretty often. I bet you won't forget next time!
jymaillat
Mar 20, 2018Tutor
I thought I had done it that way yesterday afternoon because I know it has to be done in that order but I obviously must have done something wrong earlier in the day and then did it right when I did again at night ! In any case, thanks for your response.
