DreSt56
Apr 23, 2019Aspirant
NightHawk Update
I don't have a smart phone, just a Dell laptop. Can I use the NetGear app on my laptop?
I'd like to update my NightHawk firmware but can't find the proper cable.
- Apr 24, 2019
If you're truly dedicated to making sure you do it over ethernet, they make a usb-ethernet adapter. it looks like your model has usb C and usb A ports so either adapter should work for you. Just search amazon for usb 3.0 ethernet adapter. Or usb c ethernet adapter. You'll find quite a few and then just choose the one you want.
Or you can try it over wireless.
Or even borrow someone's laptop that has an ethernet port for you to use.
Up to you which route you choose.
DreSt56
Apr 24, 2019Aspirant
Hi Plemans!
Thanks for your reply.
I see that on the front of my NightHawk P7000R, there is a USB port.
Can I use that to connect to my laptop for the update?
Sincerely,
Andre'a
Apr 24, 2019Guru - Experienced User
No. Conncecting your laptop to the router by the USB port wouldn't work with your device.
If you don't have an ethernet cable, you can do it over wireless. it'll still work this route but it's recommened to be done over an ethernet connection.
- DreSt56Apr 24, 2019Aspirant
Hi, again!
My laptop has several USB ports and a HDMI port. The ethernet cables I have access to, don't have an end that is compatible. If I were to purchase an ethernet cable, which one would work with my laptop? I'd rather not deal with any corruptions or errors that might occur doing it wirelessly.
Thanks, again!
