djdjdj
Jan 15, 2017Aspirant
Nighthawk VPN server
Hello everyone, On the nighthawk r7000 router is user vpn services for android and planning it to use for windows laptop. In the router you can download a openvpn file and instructions, it works ...
- Jan 22, 2017
Hi djdjdj,
It will still generate a new certificate so you have to redo your OpenVPN configuration.
JamesGL
Jan 16, 2017NETGEAR Employee Retired
Hi djdjdj,
You can reset the router and reconfigure the VPN service. It will generate a different certificate.
