djdjdj
Jan 15, 2017Aspirant
Nighthawk VPN server
Hello everyone, On the nighthawk r7000 router is user vpn services for android and planning it to use for windows laptop. In the router you can download a openvpn file and instructions, it works ...
- Jan 22, 2017
Hi djdjdj,
It will still generate a new certificate so you have to redo your OpenVPN configuration.
djdjdj
Jan 17, 2017Aspirant
Thanks for the response... an additional question about the solution: If i have a backup of the router settings and reset the router and put the backup back will it be the same certificate or will it be a new one so that non of the old devices can connect.
JamesGL
Jan 22, 2017NETGEAR Employee Retired
Hi djdjdj,
