djdjdj's avatar
djdjdj
Nighthawk VPN server
Hello everyone,   On the nighthawk r7000 router is user vpn services for android and planning it to use for windows laptop. In the router you can download a openvpn file and instructions, it works ...
  • JamesGL's avatar
    JamesGL
    Jan 22, 2017
    Hi djdjdj,
    It will still generate a new certificate so you have to redo your OpenVPN configuration.
