Dougster12
Oct 17, 2021Aspirant
Nighthawk won't connect to FEIT Smartplug BPPlug/WIFi/3
 I can't get my FEIT Wifi Smart Plug to cennect with my network Nighthawk Router MR 60  I get a message "Device Installation Timeout" on the FEIT install app.
Oct 18, 2021Guru - Experienced User
A couple things to try.
1. Not sure if the MR series supports wpa3 but I've found a few smart devices that struggle with it. If you're using wpa3, try disabling it and using wpa2
2. make sure your phone is connected to the 2.4ghz during setup. It shouldn't need to except for lazy coding on the app makers for devices that are only 2.4ghz capable.
Dougster12
Oct 18, 2021Aspirant
I only see one WiFi, no eparate 2.8ghz wifi.
- FURRYe38Oct 18, 2021Guru - Experienced UserThe NH MESH system broadcases 1 SSID name for both 2.4 and 5Ghz radios. Its based on a Smart Connect wifi system.
 There will be more information and help over in the NH MESH forum.Good Luck.
