Dougster12
Oct 17, 2021Aspirant
Nighthawk won't connect to FEIT Smartplug BPPlug/WIFi/3
 I can't get my FEIT Wifi Smart Plug to cennect with my network Nighthawk Router MR 60  I get a message "Device Installation Timeout" on the FEIT install app.
Dougster12
Oct 18, 2021Aspirant
I only see one WiFi, no eparate 2.8ghz wifi.
Oct 18, 2021Guru - Experienced User
The NH MESH system broadcases 1 SSID name for both 2.4 and 5Ghz radios. Its based on a Smart Connect wifi system.
There will be more information and help over in the NH MESH forum.
Good Luck.
