Blafteus
Dec 10, 2020Guide
Nighthawk X10 AD7200 doesn't like my wifi mac address (or something)
Router Firmware Version V1.0.5.24 I am having an issue that started shortly after I purchased this router in August. On my Dell Inspiron 15 5579 2-in-1 ONLY, when connected to wifi, I'm conne...
Dec 10, 2020Guru - Experienced User
does it matter if you're connected to the 2.4ghz or 5ghz?
Have you tried them both?
do you have any usb-wireless adapters you can try it with?
- BlafteusDec 11, 2020Guide
That's something I have not tested/tried. Right now I'm connected wirelessly at work with no issues. I'll be home in a few hours and will see what knocks me off.
The only thing is when it kicks me off, the adapter is completely shot until I disable/enable it. I can't even view other networks that are in range.
I do have a Cisco wireless adapter (somewhere). I'm an electronic hoarder and not very organized so it may take me a bit to find it, unless I get lucky.
I will report my findings here either way.
Thanks!
- plemansDec 11, 2020Guru - Experienced User
Blafteus wrote:The only thing is when it kicks me off, the adapter is completely shot until I disable/enable it. I can't even view other networks that are in range.
This would make my highly suspicious of the adapter. What wireless adapter is it?
I just checked Device Manager, it's listed as a Qualcomm QCA61x4A 802.11ac.
