Blafteus
Dec 10, 2020Guide
Nighthawk X10 AD7200 doesn't like my wifi mac address (or something)
Router Firmware Version V1.0.5.24 I am having an issue that started shortly after I purchased this router in August. On my Dell Inspiron 15 5579 2-in-1 ONLY, when connected to wifi, I'm conne...
Blafteus
Dec 11, 2020Guide
That's something I have not tested/tried. Right now I'm connected wirelessly at work with no issues. I'll be home in a few hours and will see what knocks me off.
The only thing is when it kicks me off, the adapter is completely shot until I disable/enable it. I can't even view other networks that are in range.
I do have a Cisco wireless adapter (somewhere). I'm an electronic hoarder and not very organized so it may take me a bit to find it, unless I get lucky.
I will report my findings here either way.
Thanks!
Dec 11, 2020Guru - Experienced User
This would make my highly suspicious of the adapter. What wireless adapter is it?
- BlafteusDec 11, 2020Guide
I just checked Device Manager, it's listed as a Qualcomm QCA61x4A 802.11ac.
Driver Date: 8/8/2019
Driver Version: 12.0.0.916
- plemansDec 11, 2020Guru - Experienced User
you're not the only one with that issue on that adapter.
https://www.tenforums.com/network-sharing/162060-qualcomm-qca61x4a-randomly-loses-wi-fi.html
https://www.tenforums.com/drivers-hardware/73701-qualcomm-atheros-qca61x4a-problem.html
the one suggestion was to lower the "roaming aggressiveness" not the lowest setting.
Not sure if thats the issue but you're not the only one with that issue on that chipset.
- plemansDec 11, 2020Guru - Experienced Usera quick search shows a ton of issues with that chipset
