trynkeepup
Aug 16, 2023Aspirant
Nighthawk X10 AD7200 LAN Ports Not Working
Hi everyone. First time needing to post anything. Bought R9000 — Nighthawk X10 AD7200 Smart WiFi Router from Amazon on 2020-08-08. The ports stopped working after a storm we had. My Xfinity modem had...
- Aug 25, 2023
Yep it ended up not being the ports, just everything that was connected. Replaced docking station, vpn hardware and NIC and it's working. Thanks for your help.
Aug 16, 2023Guru - Experienced User
Try this, disconnect the router from the ISP modem and ALL other ethernet devices.
Press the reset button for 10 seconds then release. Wait 15 seconds, then pull the power adapter from the wall out let.
Wait 1 minute.
Press the power button so it pushed out or goes to the OFF position.
Plug what power adapter back in.
Press the power button to turn ON the router.
Connect only one ethernet cable to the back of the router, try port #6.
After the LEDs are ON, try accessing the router at 192.168.1.1 with a web browser...
trynkeepup
Furrye38 will your suggestion take my router back to default settings?
