trynkeepup
Aug 16, 2023Aspirant
Nighthawk X10 AD7200 LAN Ports Not Working
Hi everyone. First time needing to post anything. Bought R9000 — Nighthawk X10 AD7200 Smart WiFi Router from Amazon on 2020-08-08. The ports stopped working after a storm we had. My Xfinity modem had...
- Aug 25, 2023
Yep it ended up not being the ports, just everything that was connected. Replaced docking station, vpn hardware and NIC and it's working. Thanks for your help.
trynkeepup
Aug 17, 2023Aspirant
Sorry yes enabled bridge mode.
One of them was a Dell docking station for my work laptop. The other was my work Aruba (hardware VPN) and my desktop integrated NIC. So yea I don't think this is the router. I'll know when I get a new docking station and a PCIe NIC for my desktop arrive and are installed. 😀
trynkeepup
Aug 25, 2023Aspirant
- FURRYe38Aug 25, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
