g0d5m15t4k3's avatar
Mar 02, 2020
Nighthawk X10 AD7200 Model R9000 will not factory reset
I have the Nighthawk X10 AD7200 Smart WiFi Router Model R9000. When I hold down the reset button, it does not reset.   1. I can confirm the lights change on the router when I hold in the reset butt...
  • g0d5m15t4k3's avatar
    g0d5m15t4k3
    Mar 11, 2020
    I ended up leaving my modem and router disconnected from power for 24 hours. Then when I powered them both on (they're on the same power supply), I held the router's reset button for 30 seconds. Inexplicably, this did the reset. Why, I don't know. Because the DHCP should have been relased regardless and have nothing to do with the router's actual settings. I don't know, I just work here.
