john8
Jan 16, 2020Aspirant
Nighthawk x10, ad7200, model,9000
have have a HP laser jet printer connected to the router via an ethernet cable. the connected port shows amber. I have powered off the xfinity modem and the routher. at time i can print at times t...
- Jan 16, 2020
thanks, i reset the printer and it works properly but i still have the steady amber light. is this speed related? john8
john8
microchip8
Jan 16, 2020Master
Yes, speed related. You printer comes with a 100 Mbps network chip. When such a device is connected to a current NETGEAR router, the router will indicate it with Amber light.
I also have a printer and a few other devices with a 100 Mbps chip and they also show amber light when connected. Nothing to worry about. It's even in the documentation of your router... google your router's model for documentation and read if you're worried
- john8Jan 16, 2020Aspirant
thank you very much. excellent solution and it works. john8
