Hankhalljr
Jul 07, 2017Aspirant
Nighthawk X10 AD7200 r9000 60GHz 802.11ad WiFi Disable
Hello, How do I enable the 60GHz 802.11ad WiFi? Router Firmware Version V1.0.2.32. When I login to the router, wireless settings is disable (red X). Please help/advise.
- Jul 23, 2017
Problem resolved, I was successfully able to disable and enable 802.11ad WiFi.
JamesGL
Jul 19, 2017NETGEAR Employee Retired
Hi Hankhalljr,
Check wireless settings under advanced tab. Make sure "Enable wireless router radio" is checked.
JamesGL
Jul 23, 2017NETGEAR Employee Retired
Hi Hankhalljr,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- HankhalljrJul 23, 2017Aspirant
- JamesGLJul 24, 2017NETGEAR Employee Retired
Hi Hankhalljr,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- AdewaleMar 16, 2018Luminarywas looking forward to finding devices that can use the 60Ghz last year. here we are and i still don't know of any device with 802.11ad capability
Does anyone know?
