TrickyWoo
Feb 05, 2021Aspirant
Nighthawk x10 ad7200 to Nighthawk ax12 ax11000 setting transfer
Hello having used the X10 nighthawk for the last 3 years, I want to now set up a new AX12 nighthawk as the main router from a virgin hub 3 without loosing all my settings and having to re-configure d...
Feb 05, 2021Guru - Experienced User
You shouldn't use a backup configuration from one device for a different one because of differences in hardware.
What you can do is use the same ssid/password on the new device and the wireless devices should auto-connect.
If you have any port forwarding rules/ip reservatios, write those down or snap a screensnip/picture.
