TrickyWoo
Feb 05, 2021Aspirant
Nighthawk x10 ad7200 to Nighthawk ax12 ax11000 setting transfer
Hello having used the X10 nighthawk for the last 3 years, I want to now set up a new AX12 nighthawk as the main router from a virgin hub 3 without loosing all my settings and having to re-configure d...
Feb 05, 2021Guru - Experienced User
You shouldn't use a backup configuration from one device for a different one because of differences in hardware.
What you can do is use the same ssid/password on the new device and the wireless devices should auto-connect.
If you have any port forwarding rules/ip reservatios, write those down or snap a screensnip/picture.
TrickyWoo
Hello again,
that is kind of what I mean't, transferring the SSID... but for a novice and none IT person I would have no idea how to do this despite the nighthawk app saying this is possible..
it will be a case of derrrrrrrr...... I have no idea.. but thank you for responding
- plemansFeb 05, 2021Guru - Experienced User
Its not hard.
Simply write down your current ssid and password. Then during setup of the new router, enter the same ssid/password as the old one. There'll be an option during setup to enter your own ssid/password and that's when you do it. Or if you miss it, you can always log into the router afterwards and change it.
