MelJim
May 13, 2021Guide
Nighthawk X10 no wifi
The 2.5 and 5 WiFi lights are not on, only the 60 light is on. I have tried turning WiFi on and off using the WiFi button on the unit and I logged in to web UI and tried disabling/enabling that way bu...
May 13, 2021Guru - Experienced User
when you pushed the button, did you hold it for at least 2 seconds?
MelJim
May 13, 2021Guide
I held it in for 5 seconds, I can see the WiFi button works because I can see the 60GHz light turn on and off but the 2.5 and 5GHz lights don’t ever turn on.
- plemansMay 13, 2021Guru - Experienced User
If you've tried that, tried a factory reset, tried reinstalling firmware (in case somethings corrupt), then you might have a hardware failure.
How old is it?
