MightyAtom
Apr 03, 2023Guide
Nighthawk (X10) R9000 - option 61
Hi, Currently in the UK my ISP is SKY. I wish to use my Netgear R9000 router (https://www.netgear.com/support/product/r9000#page-2) in place of the supplied SKY router. I see from posts online th...
michaelkenward
Apr 03, 2023Guru - Experienced User
What do you want the R9000 to do?
If it is just wifi, and/or USB ReadySHARE, you can put the R9000 into Wireless Access Point mode.
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
but then you hit this:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
What is that SKY router? They have supplied quite a few variations over the years.
What sort of Internet do you have?
What do you intend to use to connect you to the Internet? The R9000 won't do it on its own. It has no modem function.
MightyAtom
Apr 03, 2023Guide
michaelkenward I want my router simply for wifi and fixed ethernet connectivity - no file sharing.
I current have 150mbs fibre (FTTP) and when i had BT it was a simple connection from the R9000 to the optical unit in the room via an RJ45 ethernet connection - no problems!
I want to completely bypass the sky router and just use the R9000 as I did when using BT fibre service
Thanks
- michaelkenwardApr 03, 2023Guru - Experienced User
OK. Fibre and an ONT.
So you should be able to ditch the SKY box, unlike DSL, which needs a modem.
AP mode can't do that.
Did you find this?
Search - NETGEAR Communities – SKY
and
Bit of a saga.
