MightyAtom
Apr 03, 2023Guide
Nighthawk (X10) R9000 - option 61
Hi, Currently in the UK my ISP is SKY. I wish to use my Netgear R9000 router (https://www.netgear.com/support/product/r9000#page-2) in place of the supplied SKY router. I see from posts online th...
Apr 03, 2023Guru - Experienced User
Try looking at the WAN setup or maybe under Advanced Tab/Advanced settings for this menu item.
- MightyAtomApr 03, 2023Guide
Will do - thank you
- KitsapApr 03, 2023Master
Check out the bottom of the Basic Internet Setup page. Scroll down the bottom window inset.
See attached.
