SixPack
Dec 21, 2020Follower
Nighthawk X10 R9000 blocking random internet pages/devices
Good afternoon, A couple months ago we purchaed the Nighthawk X10 R9000 router for home use. It was working great until just recently. Our internet provider had an issue (a farmer drilled through...
michaelkenward
Dec 22, 2020Guru - Experienced User
SixPack wrote:
But did unplug and disconnect the router and modem a few times. I reset the fire stick to the factor settings.
When the whole network goes down, you have to reboot everything in the correct order.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
This is so that the various bits and pieces are connected before the next bit of the chain tries to establish a connection.
