nerfedweapons
Jan 06, 2017Aspirant
NightHawk x10 r9000 bottlenecking internet/ Not getting Full internet speed
I have a CM700 netgear Modem (1.4GBps capable) the R9000 currently paying my ISP for a gigabit Have had a tech come out twice to check the connections, both time, same results as follows: when ch...
- Jan 20, 2017-wired speed from the modem measured with the ISP Tech guys device was 960
-Wired speed measured with the Mac is 400
-Wired speed measured with the Xbox is 10-20
All that being said, the ISP tech came out again and ran new cables from the telephone pole and installed one of their modems, the speeds improved significantly as follows:
-wired speed with ISP Techs device is 960
-wired speed with Mac is 600-700
-wired speed with Xbox is 150-300
I think there is something wrong with the Xbox for it not to be getting the full speed but it is getting a good amount so I'm happy with it for now.
ElaineM
Jan 11, 2017NETGEAR Employee Retired
Hello nerfedweapons
I suggest that you log a case with support.
- William10aJan 20, 2017Master
What do you mean ((When checked with my laptop (2011 macbook pro, is gigabit capable, i checked multiple sources including the laptop itself):
Modem: could not connect)) did you use lan cable port to port from the modem to the Macboox? or try by wifi?
