DFnighthawkx10
Nov 26, 2018Guide
Nighthawk X10 R9000 Plex Server no longer working
My plex server has been running great on this router for quite a while. But the other day I was at someones house and logged in to my server using there Xbox One X Plex app, it played the movie and a...
- Dec 25, 2018
I have the same firmware on my R9000
Plex
Current Plex version: 1.13.9.5456-ecd600442 Nov 19, 2018
Your Plex Media Server version is up to date.
Have you tried to uninstall by deleting plex library on USB drive and then check the box again in the plex page on the R9000 and let it install again.
ClausMoeller
Dec 25, 2018Guide
Plex
- moorefredc4Jan 23, 2019Aspirant
I have the latest FW version 1.0.4.26 and on the PLEX screen in the router config i cannot get any USB drive to be recognized as being connected. I have tried FAT32, NTFS and three different models all 8GB to 64GB in size. The USBs are all recognized and work fine with ReadyShare. So I am at a loss as to where to go from here. the USB ports are working, and am thinking now that it is the FW that is causing the issue? Any advice is appreciated TIA.
- DarrenMJan 23, 2019Sr. NETGEAR Moderator
This article may be able to help you.
https://support.plex.tv/articles/230934267-netgear-nighthawk-x10-router/
DarrenM
So appreciate the link, but the problem is that no USB drives work on the PLEX server. I have one plugged in and ReadyShare sees it just fine, but on the PLEX page on the router it says No USB device connected
- DFnighthawkx10Jan 23, 2019Guide
Plex
Not sure why the forum never alerted about this answer to my issue by email. But that is exactly what I ended up doing and found thats the issue. I guess sometimes the plex files can get corrupted and deleting everything but the media files and then hooking it up again like a new drive works.
