rmsarma
May 30, 2017Guide
NightHawk x10 r9000 wifi dropping issue post f/w update
f/w updated to 1.0.2.32 otw, now i have wifi connection issues keeps dropping every few minutes, any suggestions
- May 30, 2017
I recommend doing a factory reset, manually loading the FW file, factory reset then set up the router from scratch using IE11 or FF.
Any wifi neighbors near buy? How many and what channels are they using?
May 30, 2017Guru - Experienced User
rmsarma
May 31, 2017Guide
I am not sure why the factory reset was needed, but that seemed to have improved the wifi connection issues, there is no change to my wifi surroundings and
my config below
2.4 ghz AUTO(8)
5 ghz (153)
60 ghz (2)
I did not load the F/w file as the device indicated that it was already updated
