dabears
Mar 08, 2017Star
NightHawk x10 r9000 wifi dropping issue
Hello, I just purchsed Netgear Nighawk X10 AD7200 R9000 wifi router last week and i installed the latest firmware version 1.0.1.36 and I am having issue where the WIFI SSID Drops totally from the...
- Mar 13, 2017
FYI to all:
I called Netgear support to tell them flashing the firmward didn't work, so they are going to replace the unit. I exeplained to the representative that there were mutliple users complaining of the same issue on the community site, and he told me that the team that handles the advanced issues (tiger team, he called it) told him to replace the unit. There wasn't anything else he could do.
Maybe if the next unit has the same problem they will finally engage engineering, as no one seems to be watching this community site.
dabears
Mar 13, 2017Star
I had similar issue where 2.4 GHZ wifi just dropps of the network. I did reset the device as well as flush the firmware but still no luck. There can't be two devices that are defective? I think its firmware issue. In my case the wifi drops and the white light on the router for 2.4 GHz is not ligt anymore. I am going to Best Buy today and returning this device. If i spend $500 for a device i would expect to work without any issue. Let me know thoughts?
dabears
Mar 13, 2017Star
By the way it happend last night at 11:41 PM.. dont know if that matters but i keep track of time when it happens.
- kmerenda1Mar 13, 2017Star
I haven't caught the exact time my wi-fi goes out, but it is sometime between 10p-5a.
FYI to all:
- dabearsMar 13, 2017Star
Thank you for reaching out to support for us.. but i am still not sure if they have multiple units go bad at the same time. I am going to roll back to older firmware and see if that is stable.. It could be bad stable firmware as it always happens with vendors that releases firmware without testing in the lab environment and makes customers as their QA testers and fixes the bugs along the way as we report them. If the problem still exist than i will return the router.
