dabears
Mar 08, 2017Star
NightHawk x10 r9000 wifi dropping issue
Hello, I just purchsed Netgear Nighawk X10 AD7200 R9000 wifi router last week and i installed the latest firmware version 1.0.1.36 and I am having issue where the WIFI SSID Drops totally from the...
- Mar 13, 2017
FYI to all:
I called Netgear support to tell them flashing the firmward didn't work, so they are going to replace the unit. I exeplained to the representative that there were mutliple users complaining of the same issue on the community site, and he told me that the team that handles the advanced issues (tiger team, he called it) told him to replace the unit. There wasn't anything else he could do.
Maybe if the next unit has the same problem they will finally engage engineering, as no one seems to be watching this community site.
kmerenda1
Mar 16, 2017Star
So far it has been stable, but it's only been one night. I had the old one in operation for just over a month before I had any problems.
- ElaineMMar 16, 2017NETGEAR Employee Retired
Keep us updated.
- Carlos70Mar 21, 2017Tutor
Hi my R9000 is updated to the latest firmware and when i switch it from router mode to bridge mode the WIFI signal disappear (both 2.4 and 5 GHZ).
Also it has been presenting connecting delay when trying to open sites.
I'll probabluy switch to my R8000 as it is far more stable thant R9000.
is there any firmnware uopgrade coming to solve these issues?
Carlos
- ElaineMMar 22, 2017NETGEAR Employee Retired
Carlos70 When you use Bridge mode, the router will not broadcast any SSID anymore. What it'll do is that it will connect to the main wireless router wirelessly. When it's in bridge mode you can only use the LAN portion of the unit to connect your devices.
What is bridge mode and how do I set it up on my NETGEAR router?
