dabears
Mar 08, 2017Star
NightHawk x10 r9000 wifi dropping issue
Hello, I just purchsed Netgear Nighawk X10 AD7200 R9000 wifi router last week and i installed the latest firmware version 1.0.1.36 and I am having issue where the WIFI SSID Drops totally from the...
- Mar 13, 2017
FYI to all:
I called Netgear support to tell them flashing the firmward didn't work, so they are going to replace the unit. I exeplained to the representative that there were mutliple users complaining of the same issue on the community site, and he told me that the team that handles the advanced issues (tiger team, he called it) told him to replace the unit. There wasn't anything else he could do.
Maybe if the next unit has the same problem they will finally engage engineering, as no one seems to be watching this community site.
ElaineM
Mar 16, 2017NETGEAR Employee Retired
Keep us updated.
Carlos70
Mar 21, 2017Tutor
Hi my R9000 is updated to the latest firmware and when i switch it from router mode to bridge mode the WIFI signal disappear (both 2.4 and 5 GHZ).
Also it has been presenting connecting delay when trying to open sites.
I'll probabluy switch to my R8000 as it is far more stable thant R9000.
is there any firmnware uopgrade coming to solve these issues?
Carlos
- ElaineMMar 22, 2017NETGEAR Employee Retired
Carlos70 When you use Bridge mode, the router will not broadcast any SSID anymore. What it'll do is that it will connect to the main wireless router wirelessly. When it's in bridge mode you can only use the LAN portion of the unit to connect your devices.
What is bridge mode and how do I set it up on my NETGEAR router?
- dabearsMar 26, 2017Star
Update: After getting replacement router and manually updating router with 1.1.0.36 version it hasn't gone done yet. It has been solid. Its been 2 weeks so far. Keep you posted if it goes crazy again.
- Redtulips7Mar 27, 2017Luminary
I have finish installing Nighthawk r9000 Router, so far no dropping with new non beta firmware!! But hey Netgear no QOS setting? And Devices name nad pictures are way outdated example Note 4, Window 8 etc. why not put Desktop, Laptop etc. one bad thing about Netgear, they take forever to release stable firmware, i am with Netgear over 15 yrs or more...............
- maxman1Jul 20, 2017Apprentice
I was having issues with my r9000 with Xbox online gaming lagging and dropping (connected via wireless). So I went back to my r8000 as the main router. I then changed my r9000 to bridge mode and have the Xbox One, PS3, QNAP, and Tivo connected via lan cables to the r9000. Now I have having problems with the Xbox One not connecting unless I restart the r9000 each time.
1) I am fairly pissed to move back to the r8000 because of the money I spent on the r9000. The r8000 works better than the r9000. The r9000 was supposed to be king. Now seeing these posts, it makes me think I am having the same wireless issues as others here.
2) I am even more pissed that the r9000 cannot function properly as a bridge. It is the most expensive brick I have ever purchased. One thing I notice, when the XBox One cannot connect, when I log into my r8000, the r9000 is not showing connected. AKA, if I try to log into the r9000, the page never come up. If I turn off the r9000 router and turn back on, the r9000 shows up as an attached device for the r8000, and the Xbox works.
3) I also have my r6300 connected as a bridge in another room and has giving me NO problems whatsoever. Works great all the time.
I have the latest firmware on all devices. I have reset the r9000 multiple times and configured as a bridge. The r6300 is not causing any issues as I was having this issue with the 9000 as the 6300 sat idle in my closet. When both the r6300 and r9000 show up as connected to my r8000, one other thing I notice is the r6300 is identified as r6300 while the r9000 does not show identified as the r9000, just shows dashes.
Any help?$500 is a lot of money for a device that neither works well as a router nor a bridge!
- JamesR1Jul 20, 2017Star
change the fireware to V1.0.1.36, I still have issue.....but life is better.....Netgear wrote some horrible firmware for this recently and any version newer than V1.0.1.36 has more issues
