dabears
Mar 08, 2017Star
NightHawk x10 r9000 wifi dropping issue
Hello, I just purchsed Netgear Nighawk X10 AD7200 R9000 wifi router last week and i installed the latest firmware version 1.0.1.36 and I am having issue where the WIFI SSID Drops totally from the...
- Mar 13, 2017
FYI to all:
I called Netgear support to tell them flashing the firmward didn't work, so they are going to replace the unit. I exeplained to the representative that there were mutliple users complaining of the same issue on the community site, and he told me that the team that handles the advanced issues (tiger team, he called it) told him to replace the unit. There wasn't anything else he could do.
Maybe if the next unit has the same problem they will finally engage engineering, as no one seems to be watching this community site.
Neurotix82
Jul 06, 2017Tutor
The latest firmware my device will find is v1.0.2.32
Is this update available for download somewhere aside from the router's GUI search? This could very well solve my current problem.
- DodgeDeBouletJul 07, 2017Apprentice
The beta version of the firmware under discussion here is older than the firmware version you're currently seeing as available. The wireless driver update that fixed the wifi dropping issue for most people is included in 1.0.2.32, so if you've installed it and are still experiencing a problem, it's probably not related to the fix that 1.0.2.30 (beta) or 1.0.2.32 (GA) provides.
