dabears
Mar 08, 2017Star
NightHawk x10 r9000 wifi dropping issue
Hello, I just purchsed Netgear Nighawk X10 AD7200 R9000 wifi router last week and i installed the latest firmware version 1.0.1.36 and I am having issue where the WIFI SSID Drops totally from the...
- Mar 13, 2017
FYI to all:
I called Netgear support to tell them flashing the firmward didn't work, so they are going to replace the unit. I exeplained to the representative that there were mutliple users complaining of the same issue on the community site, and he told me that the team that handles the advanced issues (tiger team, he called it) told him to replace the unit. There wasn't anything else he could do.
Maybe if the next unit has the same problem they will finally engage engineering, as no one seems to be watching this community site.
maxman1
Sep 18, 2017Apprentice
You know.. Just thinking out loud at this point, but this seems reminiscent of memory dump issues from a decade ago on old Windows.. And it would explain much.
But if this is the issue, firmware may be able to fix, but more likely is a hw problem.. Again just speculation...
Netgear has detective r9000s in its possession. Test for it.
maxman1
'Netgear has detective r9000s in its possession'.. Just to be clear my bet is they are all defective.. Most haven't noticed it..
- mkbrogSep 20, 2017Tutor
Am having constant and noticeable drop outs since updating to 1.0.2.40 firmware. Tried factory reset adn downgrading . Problem is baked in - it actually makes it impossible to use for any streaming service as the wi-fi drops out.
$700 brick at moment. Any alternative suggestions /?
- coldairSep 21, 2017Aspirant
just got our power back after Irma and found my new X10 with the wifi off, all radio freguncies set to the same to the highest number and nothing I could do would let me restart the router. rebooted the router and reset the channels and I got wifi back but I noticed that the anttena lights are no longer working I wonder if this a symptom or result of a hardware failure? hopefully I am not too late to return to amazon and I can buy a ASUS router as this is really discouraging after having spent so much with netgear switches and routers only to buy the top of the line lemon
- ElaineMSep 22, 2017NETGEAR Employee Retired
coldair What do you mean by "antenna lights are no longer working"?
Are you referring to the lights on the actual antenna or the WiFi lights?
If certain lights are not lit even after factory reset, then it's already considered faulty hardware.
Get it replaced if it's within warranty.
mkbrog Try a hard reset by following the steps below.
1. With the unit powered on, press and hold the reset button on the back of unit for 30seconds.
2. Without releasing the reset button, unplug the unit and hold reset for another 30 seconds.
3. Power on the unit while STILL pushing the reset button and count for another 30 seconds before letting it go.By the way, since you mentioned that the problem started after uploading to the latest fw version then do you still remember the previous fw where you have a stable connection?
- mkbrogSep 22, 2017Tutor
Hi - I already did a hard reste - after each firmware attempt.
It literally is unusable - the wifi and network drops consisitently.
