dabears
Mar 08, 2017Star
NightHawk x10 r9000 wifi dropping issue
Hello, I just purchsed Netgear Nighawk X10 AD7200 R9000 wifi router last week and i installed the latest firmware version 1.0.1.36 and I am having issue where the WIFI SSID Drops totally from the...
- Mar 13, 2017
FYI to all:
I called Netgear support to tell them flashing the firmward didn't work, so they are going to replace the unit. I exeplained to the representative that there were mutliple users complaining of the same issue on the community site, and he told me that the team that handles the advanced issues (tiger team, he called it) told him to replace the unit. There wasn't anything else he could do.
Maybe if the next unit has the same problem they will finally engage engineering, as no one seems to be watching this community site.
Loudog2
Oct 16, 2017Apprentice
I’m having this issue now. It started one day when all the antenna lights were off. Now the ssid broadcast disappears every couple days. Only a reboot fixes it. I recently changed my unit to AP mode, so I don’t know if that caused a hardware issue.
- headbozoOct 17, 2017Initiate
Unfortunately I must add my experience to the long litany of user experiences here.
1.) I also am experiencing the "dropped" SSID issue. Basically the unit drops all connections because it is no longer broadcasting the correct SSID and thus connected devices drop. Reboot of the router fixes the issue for an hour or so.
2.) Multiple attempts by Netgear and Gear heads has resulted in no fix, just a clear demonstration of lack of understanding of the problem ... or a front to cover up poor engineering while Netgear tries to figure out the problem and hopes the users will just give up and go away. This is no way to run a company. Dishonesty resulting in customer frustration and lost time for tech support as well as the user community. Fess up and propose a real fix, i.e.
While I am only one user and one lone voice in the wilderness can be ignored. When it becomes a chorus sometimes people will listen.
What you can do if your truely interested and frustrated enough. $500 wasted money IS significant to most people. People who spend this kind of money expect a solution of the highest calibre, generally because they have a legitimate need for it.
Here's what you can do.
1.) Do as Netgear suggests and work with their tech support. ... until your convenced, and I am, that they have no solution.
2.) Class actions have a starting point.... call your state attorney general's office and register a complaint. Enough of these comming in will get the process started.
3.) Call the vendor you used ...Walmart, Office Depot, Best Buy, etc. ... not just the local store but the corporate office purchasing department that authorizes stocking Netgear products. Shake the bushes there this will enlist their support in getting Netgear's attention.
For myself, I am the Director of Systems Architecture Services for a large east coast hosting and Managed services firm. We will now stop using netgear at all of our data centers. In addition we support 500 customers nationwide ... several large cities, and many statewide government ERP installations. I personally am called upon to recommend hardware solutions to our clients. I will not be recommending Netgear products due to this issue I am personally experiencing and the way in which Netgear has chosen to ignore the issue and its customers.
And finally, I like most of you will have to go purchase something from another vendor that works. Which is sad because this unit when it works IS the best thing out there. Unfortuneately the instability is unsatisfactory. If you find a good alternative please reply ... even though it would be kind of ironic to use Netgear's site to advertise a reliable competitor ... maybe then they'll address the issue in a professional manner.
- headbozoOct 20, 2017Initiate
While my unit is an R8500 my post is under the R9000 area so I want this reply to go along with my original post. I think this applies to both units.
It has now been 72 hours since my router was been worked on by Netgear and there has not been one problem since this last fix. I want to revise my last comments which were a bit scathing.
1.) I followed my own advice and stuck with the netgear and gearhead support and gave them a chance to resolve the issue. To their credit they stuck with me on this fix. Initially they reflashed the firmware with the latest firmware release 1.0.2.106 and the problem showed up again about two hours later. Subseqent calls produced no real fix. However ! , the next night a tech person did call back and confidently worked an hour and did the following that resulted in what I believe is a true fix.
a.) the tech re-downloaded the .106 firmware and reflashed the bios. This time however he made what I consider a better decision on the next steps. First he did a "soft reset" of the system, which I believe basically reboots the system and thus loaded the system with the new version of the firmware. Then instead of reloading the saved configuration settings from my old firmware he used the default settings that came as a part of the new firmware release. Makes perfect sense since there may have been several default settings that needed to be different in the newer firmware release and the previous tech may have been unaware of that. He followed this by changing the channel setting for the 2.4 Gig broadcaster to a specific channel as opposed to the "auto" setting. Outside of that and changing the SSID to my preferred name, the default settings were kept throughout. THIS seems to have made the system work.
SO.... in retrospect, this is what I would expect of a responsible organization. As I had mentioned earlier, the product works great when it does, and it seems to be working on now. It is not unusual for complicated full featured software/hardware to have issues from time to time and need "updates/ patches / fixes" thats the nature of this industry.
I am pleased to see Netgear step up to the plate and own the problem and solution. I resend my previous comments about not refering Netgear internally or externally. This demostration of ownership of the problem and its resolution has redeemed the organization in my mind and I will reset my thinking and recommendations accordingly.
Thanks Netgear and Gear head
- maxman1Oct 28, 2017Apprentice
Your reply sounds fishy dude...
Netgear needs to be sued into oblivion.
Awhile ago I put the r9000 back as my main router. Problems continued. It has to be reset daily. I also setup Plex. Whenever I had to reset the router, Plex would not work. I would need to unplug the USB storage, and plug back in, most of the time that worked. However, a few times, I had to completely set-up plex again; and another time I had to replace the USB drive (plugged into windows and found drive needed to be repaired).
Getting tired of restarting tthe router and my family yelling that our "internet sucks" (our internet rocks, the Netgear router SUCKS).
I put the r8000 back in as my main router tonight. Dumbass me also had bought a EX7000 a couple months ago. But funny, after putting back the r8000 as the main router, I noticed the connection between the r8000 and EX7000 was near 100MB/Sec as I tested sending files from the r8000 to a server connected to the EX7000. the r9000 never sent this fast!
It got me thinking...so I just spent a few hours testing the r9000 as a bridge.
I have a PC in a room that is about 40 feet from the main router. It has been connected via LAN (gigabyte) to my old netgear 6300 router that is set up as a bridge. Using Bing Speed Test (that comes up when you bing "Speed Test") as well as speedtest.net, I averaged anywhere from 85mb/s to 90mb/s download and 10 to 15mb/s upload.
I moved the EX7000 to the same room, I connected the same PC and tested the speed.The two speed tests showed 95-99mb/s download and 15-18mb/s upload.
I set up the r9000 as a bridge in the same room. 40-45 mb/s download and 8-10 mb/s upload.
The r9000 is by far the worst. It isn't even close. Heck, my on board WiFi was almost as fast as being connected via LAN to the r9000!
I also tested sending files from the PC to a server connected to the r8000. I could never manage to send faster that 5-6 mb/s, yet when connected to the 6300, I could send between 11-12 mb/s!
You know how many swear words I want to write to you Netgear! This piece of crap doesn't work as a router, works worse as a bridge than routers 7 years old, and has WASTED so much of my time that it is unreal!
It is now completely removed from my home network and I WANT MY MONEY BACK (and more) for all the time wasted!
If I do not get compensated I will be sending this to an attorney who specializes in lemon products. This is worse than a brick, because at least a brick has a purpose.
Any person reading this, DO NOT BUY ANYTHING NETGEAR! They do not stand behind their products and their customer service is worse than laughable!
