dabears
Mar 08, 2017Star
NightHawk x10 r9000 wifi dropping issue
Hello, I just purchsed Netgear Nighawk X10 AD7200 R9000 wifi router last week and i installed the latest firmware version 1.0.1.36 and I am having issue where the WIFI SSID Drops totally from the...
- Mar 13, 2017
FYI to all:
I called Netgear support to tell them flashing the firmward didn't work, so they are going to replace the unit. I exeplained to the representative that there were mutliple users complaining of the same issue on the community site, and he told me that the team that handles the advanced issues (tiger team, he called it) told him to replace the unit. There wasn't anything else he could do.
Maybe if the next unit has the same problem they will finally engage engineering, as no one seems to be watching this community site.
xnsys
Dec 11, 2017Luminary
I've just received one in the mail today - and guess what....Both my Apple TV's keep dropping out on the 2.4GHz range.
BUT.... I have found the fix.
Change the 2.4GHz range to NOT use the 20/40 MHz Coexistence - and no more disconnects.
There are other issues with the router, which I will not go into here and will create a new post with the details in.
Awsam
Dec 12, 2017Tutor
This fixed my issue to a point. Once Coexistance was disabled, NOTHING would connect or even discover 2.4 lol! So I guess you can't disconnect if you never connected ;)
