Velcnet
Jun 14, 2017Aspirant
Nighthawk x10 two questions
Greetings, have two questions about r9000: 1. How I can change time zone for router? 2. Looks like router restarting by himself sometimes. Log shows events after rebooting only. Is there any chanc...
- Jun 14, 2017
Is QoS enabled? Disable to see if router stops rebooting.
Jun 14, 2017Guru - Experienced User
Velcnet
Jun 15, 2017Aspirant
FURRYe38, should I disable Dymanic QoS only or WMM for both 2.4 and 5 bands as well?
- FURRYe38Jun 15, 2017Guru - Experienced User
Just QoS. Keep WMM enabled. Can test WMM disabled later.
- VelcnetJun 16, 2017Aspirant
Thanks, FURRYe38,
now looks better. Is Dynamic QoS unstable? Is this for all Netgear routers or only R9000 issue?
- FURRYe38Jun 16, 2017Guru - Experienced User
QoS was fully intro'd in v.32 so it may have some issues. One user mentioned that he reverted back to v.30, then manually updated back to v.32 and seems to be working.
You could try this. Factory reset the router between each FW load then one last reset then set up from scratch.
